Tagged: 18.2, ansys-workbench, fluid-dynamics, General, meshing
August 25, 2023 at 12:16 pm
FAQParticipantIn Workbench meshing application, there are tree filter options inside “Outline” panel just above ”Project”. In those filter options, the last option is for arranging tree items in ascending order. Clicking this option will rearrange all Named Selections in alphabetical order. Refer attached image which shows this option.
- Skewness in ANSYS Meshing
