In Workbench Mechanical, why mass transport element Solid70 has not effect in steady-state thermal simulation?
Tagged: 19.2, mechanical, static, structural-and-thermal, structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantDensity and specific heat need to be added for the material in Engineering data, otherwise the mass transport will have not effect.
