In the course СFX Combustion_Radiation, the lecture on Radiation provides coefficients for Weighted Sum of Grey Gases model (WSGGM) for methane How can I configure the WSGGM for propane and ethane?Is there a way to fit those coefficients?
March 17, 2023 at 8:59 am
FAQParticipantThe WSGG model coefficients given in the CFX Combustion and Radiation course can be used for any hydrocarbon fuel. In fact the fuel itself makes a small contribution relative to CO2 and H2O.
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
