Licensing
Licensing
In RSM Configuration 19.1, when “Submit host” is set to an alias (which can be resolved to correct IP address on both client and server) of a remote Linux machine running RSM Launcher 19.1 service, RSM job may fail with below error after input files are uploaded: Submit Failed Credentials not cached for desination: XXXX XXXX is the “Name” of HPC Configuration in HPC Resource tab in RSM Configuration 19.1 on client.
    • FAQFAQ
      Participant
      Change the “Submit host” from an alias to the real hostname or IP address (accessible from client) of the remote Linux running RSM Launcher 19.1 service. It seems RSM 19.0 and prior releases don’t have such issue (alias can work).
