March 2, 2022 at 3:28 am
FAQParticipantBy default, for most of the nonlinear analysis the stiffness update is done for each iteration in Ansys. But how to update the stiffness during the nonlinear Newton Rapshon solution procedure can be controlled with NROPT command.
