In my ANSYS License for ANSYS HPC & ANSYS HPC Pack, I have SIGN & SIGN2 as ‘feature qualifiers’ Which one should be used? Also, I do not see “KEY=” in the increment line.
April 5, 2023 at 2:32 pm
FAQ
ParticipantKindly check existing ANSYS License Option file (If you already using ansyslmd.opt) Between SIGN & SIGN2, you should use SIGN. If you were using “KEY=” ‘feature qualifiers’ to use the specific feature line now you can use “SIGN=” in place of “KEY=” Example: INCREMENT anshpc_pack ansyslmd 2018.1231 permanent 4 VENDOR_STRING=customer:0123456 SUPERSEDE ISSUER=SIEBEL ISSUED=28-dec-2017 START=28-dec-2017 AUTH={ ansyslmd=( LK=E5A91D350693 SIGN2=”0056 49F4 C523 AE77 DE3D 3867 91C3 DC00 81ED B86F B9C7 4FD8 6A96 76A8 C679″) ansoftd=( SIGN=”0042 83EF 757B 6C98 0A65 D49E 8A9F 6200 510E 5E82 EF08 CEAB 5704 C799 357E” SIGN2=”00FE 89EC B9DF E236 6558 9FDA 7700 9800 334D 5BA1 1E91 A60E A1E4 2685 A7FE”) } RESERVE 1 anshpc_pack_SIGN=”0042 83EF 757B 6C98 0A65 D49E 8A9F 6200 510E 5E82 EF08 CEAB 5704 C799 357E” USER John
