Structural & Thermal
In Mechanical, how to report Inertia Relief summary for each load step?
    • FAQFAQ
      Participant
      By default, Inertia Relief summary is reported for the last step. To report it for each load step, add a command object with command “irlist”. In the details of this command object, make sure set “Step Selection Mode” to “All”. You will find Inertia Relief summary for each step in solver output.
