Tagged: 19.2, General, mechanical, static, structural-and-thermal, structural-mechanics
April 13, 2023 at 7:32 am
SolutionParticipantThis solution explains how to easily export many reaction forces to a text file that can be later used in Excel. Several methods can be considered: (1)Create a chart and export the chart values (2)Use the “Result Summary” functionality Please refer to attached document
1. 2056766.pdf
