In Heterogeneous reaction, Fluent Theory Guide says: ANSYS Fluent assumes that the reactants are mixed thoroughly before reacting together, therefore the heat and momentum transfer is based on this assumption. This assumption can be disabled using a text command. For more information, contact your ANSYS Fluent support engineer.
January 25, 2023 at 7:17 am
FAQParticipant(mp/mt/heat-transfer? #t boolean) ;if to transfer heat also in mass-transfer (mp/htrxn/mom-transfer? #t boolean) ;if to transfer mom. also in het. reactions Please set these rpvars to FALSE.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
