April 5, 2023 at 2:32 pm
FAQParticipantFor some mesh smoothing methods in Fluent (diffusion smoothing), the mesh is moved in a preliminary step to evaluate the boundary conditions for the mesh smoothing equations. After this test, the mesh is reset. So ultimately the mesh motion is only applied once.
- Skewness in ANSYS Meshing
