In Fluent for UDF, how can I access Mixture Fraction and Progress Variable? I cannot find these variables listed under Flow Variable Macros for Cells.
Tagged: 19, fluent, fluid-dynamics, Scripting/Journaling/UDF, Species/Reactions
April 5, 2023 at 2:32 pm
FAQParticipantThe mean mixture fraction and progress variable can be accessed for UDF at the cell level using C_FMEAN(c,t) and C_PREMIXC(c,t)
- How do I model humidity in Fluent?
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Model setup: Setting up chemical reactions
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
