March 17, 2023 at 8:58 am
FAQParticipantBy using the following python script, one can print out the RGB values of each of the levels of a palette hat is assigned to a specific variable from ensight.objs import * for v in core.VARIABLES: if v.DESCRIPTION==’Density’: print v.PALETTE[0].LEVELS_AND_COLORS There will be a list that is output which contains 5 numbers for each of the levels. These numbers indicate the Level Value, Red Value, Green Value, Blue Value, Alpha Value respectively of each of the levels.
- Skewness in ANSYS Meshing
