Tagged: Ansys Discovery, contacts, force, Joints, local sizing, Manual Contact, material definition, mesh settings, Meshing Options, Physics Tab, Post Processing Options, Real-Time Geometry Changes, Result analysis, Simulation Information Display, Simulation Ribbon, stress, structural, structural-analysis
April 12, 2023 at 9:36 am
Watch & Learn
ParticipantThis four-part in-depth video tutorial covers structural simulation in Ansys Discovery 2021R1. Although the tutorial is performed in an older release, the features discussed are valid in newer releases as well. If you are looking for tutorials in the newer release, please refer to the Structural Simulation course for 2024R1: Structural Simulation Using Ansys Discovery | Ansys Courses
You can download the CAD Files from this link: Download CAD file
Structures In-Depth – Part 1
In first part of the structures In-Depth tutorial, we will cover importing the geometry for structural simulation and preparing the geometry. We learn how to include, exclude parts for simulation, use of Move Tool for orienting, aligning, removing gaps and penetrations between bodies. Learn how Fill Tool helps us defeaturing the geometry by removing the fillets, threads so that we can reduce the mesh count.
Structures In-Depth – Part 2
In second part we will learn how to assign the material and boundary condition for structural simulation on our suspension geometry. Specifically, we see how to apply hinged support, force based on the vector components. We can change the default Structural Steel material from the material library or edit the default material properties to create your own material.
Structures In-Depth – Part 3
Third part covers contacts and joints setup in Ansys Discovery. Contact Review Tool helps us identify contacts pairs and change the contact behavior to sliding, prevented or exclude from contact detection. We can group faces by body, tangent faces or set no grouping. Discovery allows you set manual contacts by defining primary face selection and secondary face selection. Finally, we learn how to define hinged joint.
Structures In-Depth – Part 4
Fourth part covers simulating the setup in Refine mode and post processing of the results. Refine mode uses the flagship mechanical solvers you can check the simulation progress in the SID (Simulation Information Display) once the simulation is 50% complete you can visualize the mesh by clicking on “Show Mesh” button. Once the solve is complete you can view different result like displacement, stress, contact stress etc.
Note: Ansys Discovery 2024R1 version onwards you can create mesh before solving by clicking on the “Generate Mesh” button from result arc, review and make any changes to the mesh than start the solve.
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Structural Simulation using Bolt Idealization
- Ansys Discovery: Topology Optimization
- Thermal Analysis of Heat Sinks with Ansys Discovery
- Discovery – Defining new material
- How to apply bolt Pretension in ANSYS Discovery?
- Discovery Quick Tip- Understanding Contour Settings
- Ansys Discovery- Intake and Exhaust Fan for Fluids
- Discovery Explore: How to retain a certain portion of the geometry in topology optimization?
