In CFX-post, sometimes when loading in large cases on windows 64 bit computer, Post will complain: ERROR in LoadDat
March 17, 2023 at 8:58 am
FAQParticipantThere is an internal socket buffer size limit on windows XP 64bit, once the case exceeds this limit, Post will echo out the above error message. The work around is to set the following environment variable: COMPRESSBUFFERSIZE=1024.
- Skewness in ANSYS Meshing
