Tagged: 2022 R1, BladeGen, BladeModeler, fluid-dynamics
March 17, 2023 at 8:57 am
FAQParticipantThere are a few things that can cause this. Here are two things to check: Right click in the Meridional view and select Display Interpolation Grid. Ensure that none of the grid lines cross. If they do, try moving the segment points in the Meridional view. Right click in the Meridional view and select Meridional Control Curves > User-Defined. Ensure that none of the curves meet at a single point. If they do, move the segment points, or split the segment to add new segment points.
- Skewness in ANSYS Meshing
