In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
January 25, 2023 at 7:17 am
FAQParticipantConsider flow through a capillary ID 1 mm, Length 20 mm, adiabatic wall and inlet velocity 0.02 m/s, 300 K. The fluid has a viscosity = 0.8 Pa-s, density = 600 kg/m3, thermal conductivity = 0.1 W/m-K, and specific heat = 2600 J/kg-K. Therefore, the Ryenolds number is very low, Re = 0.015, and the Prandtl number if very high, Pr = 20800. In such a case, when you turn on viscous heating only, the outlet temperature will be LESS than the inlet temperature! This problem is rectified by turning on pressure work. The procedure will be explained and described further below. We know h = u + P/rho where h = specific enthalpy; u = specific internal energy; P = pressure; rho = density. Hence delta(h) = delta(u) + delta (p/rho) = delta (u) + P.delta(1/rho) + (1/rho).delta(P). For incompressible liquids with constant density, P.delta(1/rho) = 0; but, we need to account for (1/rho).delta(P). For gases, both incompressible and compressible, depending upon whether it is constant volume or constant pressure process, the appropriate pressure work remains. When viscous heating is turned on, the increase in enthalpy needs to be accounted for by the pressure work term. Otherwise, as in the sample problem case, you will see a fictitious drop in exit temperature to satisfy the enthalpy balance. How to turn on Pressure Work in ANSYS Fluent? In the text interface Define->Models->Energy; Fluent will prompt you for inclusion of viscous dissipation term, pressure work term, kinetic energy term.
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- Simulating Battery Pack Cooling System Using Ansys Fluent
- How to add comments to journal file so that I will know what each entry does?
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
