In a transient thermal simulation involving phase change, why is the enthalpy change not calculated even though it is defined?
Tagged: 18.1, mechanical, static, structural-and-thermal, structural-mechanics
April 5, 2023 at 2:32 pm
FAQParticipantThe default solver that is picked is the Quasi Static solver, which does not take into account enthalpy calculations. The user must manually set the solver option to Full Newton-Raphson for the enthapy to be taken into account.
