Tagged: 16.2, contact, mechanical, structural-and-thermal, structural-mechanics
May 15, 2023 at 8:33 am
SolutionParticipantYes. Please refer to the attachments to access the Solution.
1. 2052195.zip
2. Rotational%20Velocity%20Vs%20Interference%20Study.pdf
