June 3, 2022 at 1:43 pm
Watch & LearnParticipantThis video demonstrates the steps for converting Zuken CR8000 to SIwave & 3D Layout. It shows how to include .idf data within SIwave for Icepak simulation. ANSYS Electronics Desktop integrates rigorous electromagnetic analysis with system and circuit simulation in a comprehensive, easy-to-use design platform. Note: The export and import features shown in the drop down menu within Design Force CR-8000 can be purchased from Zuken , Inc.
