Importing Initial stress via external data import, after solution the resultant stress does not match the imported stress
Tagged: 19.2, General, mechanical, static, structural-and-thermal, structural-mechanics
March 17, 2023 at 1:11 pm
SolutionParticipantInitial stress may not match with the result if the boundary conditions are insufficient to hold the stress from dissipating. See the attachments for reference.
1. 2057652.zip
2. Initial Stress via External Data.pdf
