Implementing using Matlab-Ansys Integration. So fluent is set to be enabled in AAS mode. FLUENT fails to solve the case with “solution update” or “iCoFluentUnit.calculate()” or “tui.doMenuCommand(‘solve iterate 1000’) – Error pops up as shown below. “Error: wta(1st) to string_append Error Object: ()”
Tagged: 19, fluent, fluid-dynamics, General, General - FLUENT
January 25, 2023 at 7:16 am
FAQParticipantThis error comes in R18. This is fixed in R19. Please use R19.
- Skewness in ANSYS Meshing
