I’m running Tetra on my HP-UX machine, and I’ve specifiied 2 processors within ICEM, but it only seems to report one processor in usage.
March 17, 2023 at 8:58 amFAQParticipant
“Top” on HP is a little different than on other operating systems. It will only show one “tetra” process. What you need to monitor is the load distribution for both processors at the top of the shell when you run “top.”
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
