If Workbench 11.0 is already installed on a Windows x64 system and Pro/E is then installed after it, can I use Add/Remove Programs and then choose Modify to add the Pro/E Plugin to Workbench?
March 17, 2023 at 9:01 am
FAQParticipantNo, running a Modify on Windows x64 will not work since it does not set the PROE_START_CMD environment variable. The easiest way to add the Pro/E Plugin is to uninstall/reinstall Workbench 11.0.
