If we slice an extracted fluid volume in SCDM with symmetry plane, an update of the geometry (e.g. by changing a driving dimension of the solid volume), does it result in an update sliced extracted fluid volume?
March 17, 2023 at 8:58 am
FAQParticipantAn update will result to a extracted volume based on the solid volume. The slice is not applied. We would need to extract the fluid volume from the sliced solid volume.
- Skewness in ANSYS Meshing
