Tagged: 16, fluent, fluid-dynamics, General, General - FLUENT, MHD/EHD
January 25, 2023 at 7:16 am
FAQParticipantIt is possible to use the external magnetic data from experiments. The data is saved in the format as described in the MHD User Guide. The range covered by the field data and the number of data points in each direction are determined by the user. It should be noted that the saved data points must be evenly distributed in all three (X, Y, Z) directions. For DC data the imaginary components of each data point are set to zero.
- Skewness in ANSYS Meshing
