If the solution cell is set to update via RSM, and there are 10 design points being updated, 10 jobs will be submitted to the server taking up many licenses. Is there a way to restrict license usage when using solution cell update via RSM?
Tagged: 18.2, FLUENT - SYS, Installation/Licensing/Systems, Remote Solve, rsm
June 5, 2023 at 7:05 am
FAQParticipantThe assumed behavior is that you want to run the jobs as fast as possible so it will submit all DPs at once. If you want to limit the amount of jobs submitted, instead of submitting the solution cell to RSM, submit the parameter to update via RSM, since there is an option to submit one job for all design points, effectively limiting the license usage for the update. If you’re using the ARC scheduler, there are some ARC options to limit how many jobs a user can have active at once. This solution is applicable to all physics applications.
