If SpaceClaim Direct Modeler issues the message “Cannot open the document. Reason: Failed to load body geometry.” and then opens without any model, is it possible to recover the original model?
June 6, 2022 at 10:33 am
FAQ
ParticipantOne can try the following:
1. In Windows, rename the design file to a .zip file to allow you to open it as a normal zip file. For example, rename Design1.scdoc to Design1.zip.
2. Within the zip file, navigate to SpaceClaim > Geometry and extract the allpartbodies.sab file. It is a standard ACIS file. You can usually copy and paste it to the main folder.
3. Import allpartbodies.sab into SpaceClaim using the ACIS file type.
- How to reverse surface normal in SpaceClaim?
- How to Change the Direction of the Normal Vector of the Internal Face?
- Create Sections in Meshing
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- ANSYS ICEM CFD: Basic Blocking
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- How can I create a 2D section from a 3D model in SpaceClaim ?
- How do you turn a rectangular surface mesh into a triangular surface mesh?
- What is meaning of message: One or more objects may have lost some scoping attachments during the geometry update.
- What is the difference between patch dependent meshing and patch independent meshing?
