If SpaceClaim and DesignModeler are not available, can I use command object inside Mechanical to add cross section to line bodies?
June 6, 2022 at 10:33 am
FAQParticipantNo, the beam geometry (line bodies) can only be added by DM/SCDM or simply importing third party model into ‘Geometry’ cell of the analysis system. Command object in Mechanical can replace/revise the original definition of line body and the cross section information, but initial definition is processed from the ‘Geometry’ cell.
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- Create Sections in Meshing
- How to reverse surface normal in SpaceClaim?
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS ICEM CFD: Basic Blocking
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- Fluent: Watertight Geometry Meshing Workflow
- How to Fix the Error: “Mesh Exporter does not Support Overlapping Geometry in Named Selections”?
- How can I create a 2D section from a 3D model in SpaceClaim ?
