Licensing
Licensing
    • FAQFAQ
      Participant
      This happens if BladeEditor license is used instead of the DesignModeler license. The BladeEditor add-in purposely removes the Reset Layout menu item when DesignModeler runs with that dedicated BladeEditor license. If BladeEditor is not required please check under User License Preferences that the DesignModeler license is the first license which needs to be checked out.
