If I have only one R19 EnSight license, can I use EnVision Pro simultaneously if one instance of EnSight is already open?
Tagged: ensight, fluid-dynamics, General, post-processing
April 5, 2023 at 2:33 pm
FAQParticipantIf you have “envision pro” in your license then if you can open EnVision Pro simultaneously with one EnSight session opened.
- Skewness in ANSYS Meshing
