If I am given mass flow rate, temperatures, pressure data from experiment for flow entering a pipe, I noticed the mass flow rate inlet bc only applies the temperature/pressure if the flow is supersonic. What would be the best method to apply these type of inlet bc to a compressible gas type problem?
Tagged: 17.2, compressible-flow, fluent, fluid-dynamics, Modeling/Setup Advice
August 25, 2023 at 12:15 pm
Solution
ParticipantPlease see attached document. Keywords: compressible flow, inlet boundary conditions, mass flow rate
1. 2045941.pdf
- Skewness in ANSYS Meshing
