If a lower-order (linear) element is specified, how does Mechanical choose the appropriate element type?
Tagged: 19, mechanical, meshing, modeling-and-meshing, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantMechanical meshes on part-by-part basis. When a lower-order structural element is requested, the mesher asks two questions before meshing each part. 1. Will the entire part be meshed only with tetrahedral elements, and 2. Is a nonlinear material defined for any body in that part? If the answer to both of those questions is yes, then the mesher uses SOLID285 for the entire part. If the answer to either of those questions is no, then the mesher uses SOLID185 for the entire part. Also, if the entire part is meshed with only tet elements, other nonlinear option (e.g., NLAD) may also trigger the mesher to use SOLID285 rather than SOLID185. Note: Tetrahedral SOLID185 elements are not recommended, particularly for non-linear applications.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
