Tagged: 2019 R1, fluid-dynamics, fluids, General, icem-cfd, Tetra/Prism
April 13, 2023 at 7:32 am
SolutionParticipantBad mesh projections can happen when the mesh element sizes are large in comparison with the scale of the geometry. Reducing the Edge Criterion may can solve the problem It may also be necessary to manually adjust the mesh sizing so that small features can be captured fully. These adjustments will generally ensure that mesh is correctly projected on edges/surfaces. If you are creating a hex mesh, make sure that you split the edges of blocks correctly and assign them to respective curves. If a curve spans only part of a block edge, the mes will fold. Faces with high curvature may require manual projection of block face to underlying surfaces.
1. 2058512.pdf
- Skewness in ANSYS Meshing
