General
General
ICEM issues a message “Note that the executable “prism_v10.exe” (for option “Use prism V10”) needs to be obtained from the ANSYS customer portal and copied to “C:/Program Files/ANSYS Inc/v180/icemcfd/win64_amd/icemcfd” Is this out-of-date? I can’t find the .exe on the customer portal.
    • FAQFAQ
      Participant
      Prism V 10 exists in releases up to V17.2 in C:Program FilesANSYS Incv172icemcfdwin64_amdicemcfd If you need it, you can copy it from an older version and move it into place, since it is unchanged, release to release. Prism V 10 is deprecated for most users, unless you are trying to reproduce a mesh that dated back to the ICEM V 10 release.
