I would like to solve a user scalar transport equation in ANSYS CFD with advection and zero diffusion. When I set diffusion to zero, there is an error. How can I eliminate diffusion and still solve my transport equation with the flow?
January 25, 2023 at 7:16 am
FAQParticipantThe treatment of quantities that are exactly zero is subject to the math processor of the machine, if a divide by zero is encountered. Warnings are issued to prevent this, or indicate that it is occurring. Diffusion (even with significantly non-zero coefficients) is a very slow process, so the effects of a low diffusivity on the scalar streamlines will be negligible (unless the residence time is huge). The best practice (to avoid the pitfalls of divide-by-zero calculations), is to set the diffusivity to something just above machine round-off, (ie: 1.0e-15), and solve with double precision.
- Skewness in ANSYS Meshing
