I would like to display the contours of the sensitivities (Normal Optimal Displacement) but I can’t get them on the .cas and .dat after saving and reading them, I have a field at zero.
January 25, 2023 at 7:16 am
FAQParticipantOne can process sensitivity data before calculating the design change. But design change calculation is required to process the optimal displacement. Optimal displacement is not saved in the result file.
- Skewness in ANSYS Meshing
