I want to use Fluent to model a porous zone that has reaction. Can I do this with an internal porous jump surface?
Tagged: 18.2, BCs & Interfaces, fluent, fluid-dynamics, materials, porous-media, Reactions, species, Species/Reactions
March 17, 2023 at 6:12 am
FAQ
ParticipantInternal surfaces cannot support surface reaction, as they are not walls. The best approach here is to model a single cell thickness porous zone and apply volumetric reaction.
- How do I model humidity in Fluent?
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- Model setup: Setting up chemical reactions
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How do I use the Flamelet Generated Model?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
- How can volume fraction be plotted in a species transport simulation?
- Configuring and Solving the Chemical Species Transport in Fluent
