March 17, 2023 at 9:00 am
FAQParticipantYou can use ‘MAX’ in ansys license option file (ansyslmd.opt) ‘MAX’ option applies to concurrent licenses held in license file. This limits usage for a group or user. Syntex: MAX num_lic feature[:keyword=value] type {name | group_name} Example Option file with MAX: # Disables case sensitivity when defining groups/host_groups GROUPCASEINSENSITIVE ON GROUP ANSUSR usr01 usr02 usr03 usr04 usr05 MAX 2 meba GROUP ANSUSR MAX 1 preppost GROUP ANSUSR MAX 1 acfdsol2 USER usr06 MAX 1 anshpc_pack_VERSION=9999.9999 GROUP ANSUSR
