Tagged: 19, General, mechanical, static, structural-and-thermal, structural-mechanics
March 17, 2023 at 9:00 am
FAQ
ParticipantWe do not have any direct option to access SMXB, SMNB in ansys workbench. To calculate it in workbench mechanical,To calculate it in workbench mechanical, you need to do mathematical calculations using ACT or use a command object similar to this: /graph,full set,last prns,s,comp ! shows bounds in output ! /sho,png plns,s,x ! plot required to use *get *get,bmn1,plnsol,,bmin *get,bmx1,plnsol,,bmax
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
