I used to import an image in SpaceClaim using Insert tab. But I can not find it in 2020R2. Is it removed?
April 13, 2023 at 7:32 am
SolutionParticipantIn 2020R2, you can import image in SpaceClaim using Assembly –> File option. Here you can select the image file and open it in SpaceClaim. Keywords: import, image, insert, assembly
1. 2063986.pdf
- Skewness in ANSYS Meshing
