I use Scheme syntax to facilitate my Fluent session. How can I do this automatically when launching Fluent from Workbench?
June 5, 2023 at 7:06 am
FAQParticipantIf you right-click on the ‘Setup’ cell for Fluent from the Workbench schematic, you can choose the option to ‘Register a Startup Scheme File’. This way, for example, if you are using Design Optimization, the Scheme file will be applied each time a design point is solved.
- Skewness in ANSYS Meshing
