I try to run a Functional Mock-up Interface (FMI) Co-simulation in CFX. The FMU was written in Modelica and exported by Dymola. When I run the simulation, CFX reports an unspecific error with the FMU and stops. What could be the reason for this?
Tagged: 2019 R1, cfx, fluid-dynamics, FMU, General - CFX
March 17, 2023 at 8:58 am
FAQParticipantIf you see an error message that is similar to this one for a Dymola-generated FMU: ERROR #999100420 has occurred in subroutine fmi2InstantiateF. Message: Functional Mockup Unit (FMU) error: – FMU instance : NameOfFMU – FMU error : fmi2Error the reason could be that you compiled the FMU in a way that requires a Dymola license for the execution of the FMU and you don’t have access to the required license. In this case, the modelDescription.xml will contain an entry like generationTool=”Dymola Version 2019 (64-bit), 2018-04-11 (requires license to execute)” Instructions on how to compile the FMU such that no license is required for the execution of the FMU can be found in the Dymola documentation.
- Skewness in ANSYS Meshing
