I try to plot a variable against Curve Length in my XY plots, I get the error message: “Cannot plot along curve length of “surface name” ” This seems to affect some surfaces and not others. Why? In some of my models, I can’t do Curve Length plots for any of the surfaces.
Tagged: 18, fluent, fluent-post-processing, fluid-dynamics
June 5, 2023 at 7:06 am
FAQParticipantIf a curve is split over 2 or more partitions, Curve Length XY plotting fails to work. With the same case in serial, the plotting will work.
- Skewness in ANSYS Meshing
