I see the error message “Failed to enable feature using current settings…..” when I try to run a simulation.
Tagged: 2020 R1, HFSS - SYS, Installation/Licensing/Systems, PPE
March 17, 2023 at 1:11 pm
SolutionParticipantPlease select the option “Use Electronics Pro, Premium, Enterprise product licensing” This is available via Tools > Options > General Options and is the first item you see at the top of the window when “Desktop Configuration” is selected.
