I realize a steady state thermal analysis and I need to find the proportion of a face which is over a specific temperature.
August 25, 2023 at 12:16 pm
Solution
ParticipantThe best way is to use APDL in Mechanical. First, create a named selection of the face and then use the *DO and *GET command in order to find the nodes for which the temperature is over the criterion. Find attach a WB archive file which show the APDL command to use.
1. 2039838.zip
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
- ANSYS Mechanical: Fatigue Crack Growth Analysis using SMART Crack Growth
