I ran a transient flamelet (partially premixed combustion) case and forgot to do a statistical average of density, but I averaged other key variables. How can I get the time-averaged density without rerunning my transient simulation? Can I get it from the PDF tables?
Tagged: 18.1, BCs & Interfaces, fluent, fluid-dynamics, materials, Reacting Flow, Species/Reactions
June 5, 2023 at 7:06 am
FAQParticipantThe PDF table has an encrypted format that is proprietary, so no calls can be made to it to retrieve density. However, density can be estimated from the ideal gas law, or an approximation equivalent to that made in the PDF tables.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- How do I use the Flamelet Generated Model?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- How can volume fraction be plotted in a species transport simulation?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
