I import STL of deformed shape of shell body from Mechanical to SCDM. Why can’t I get a good STL when shell thickness is turned OFF?
March 17, 2023 at 9:00 am
FAQParticipantWhen you turn off the thickness, the two skins of a shell body simply collapses. That means there are still two surfaces of a shell but zero gap between them. Due to zero gap, these STL elements of the two skin get connected together which makes it duplicate elements and intersection.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
