I have used watertight workflow. Now I want to create a journal file which will generate similar mesh outside the workflow. Do you have a basic example?
Tagged: 2021 R1, FLUENT Meshing/Tgrid, fluid-dynamics, meshing
April 13, 2023 at 7:32 am
SolutionParticipantMany mesh scenarios are available in the Workflow which can be more or less complicated to replicate outside the Workflows. You can find in attachement a geometry and a Fluent Meshing journal file for a simple example. Keywords: journal, watertight, script
1. 2066245.zip
- Skewness in ANSYS Meshing
