I have thermal BC for a wall specified as ‘radiation’ or ‘mixed’, but the ‘radiation heat transfer rate’ always reports as 0. Why?
Tagged: 18.1, fluent, fluid-dynamics, Heat Transfer and Radiation, heat-transfer, Other
August 25, 2023 at 12:16 pm
SolutionParticipantPlease see attached document for solution. Keywords: radiation, heat transfer rate, mixed, thermal bc
1. 2050741.pdf
2. 2050741.zip
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
