I have stationary inlet and outlet zones and one rotating zone. If I physically move rotating zone mesh with periodic symmetry, now my interface between moving and stationary zone is off. What is the approach here to set periodic?
January 25, 2023 at 7:16 am
FAQParticipantYou will need to turn on Periodic Repeat option when creating interfaces for such a scenario. Once this is turned on, the non-overlapping part of the interface is no longer treated as walls. Rather, the two non-overlapping part will interact with each other.
- Skewness in ANSYS Meshing
